Dell Latitude E6320 Hard Drive Replacement
  1. Dell Latitude E6320 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6320 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Shut down your computer. Disconnect all power sources before starting physical work.
    • Slide the two latches each side of the battery outwards. You'll notice you've unlatched the battery from the chassis when you hear two clicks.
    • Don't do this while the computer isn't upside down! When you lift up the computer to turn it over, you could damage the battery or injure yourself or someone else.
  2. Dell Latitude E6320 Hard Drive Replacement: step 2, image 1 of 3 Dell Latitude E6320 Hard Drive Replacement: step 2, image 2 of 3 Dell Latitude E6320 Hard Drive Replacement: step 2, image 3 of 3
    • To remove the battery from the chassis, pull it up from underneath the top of the battery.
    • The latches should relatch back to their original position once you pull out the battery,
    • Place the battery on a sensible surface, where it won't fall down.
  3. Dell Latitude E6320 Hard Drive Replacement, Hard Drive Screws: step 3, image 1 of 2 Dell Latitude E6320 Hard Drive Replacement, Hard Drive Screws: step 3, image 2 of 2
    • Remove the four Phillips #00 screws that secure the hard drive to the computer.
    • If you can't be bothered taking a look at the provided images, you'll see the screws indicated by the same hard drive icon that lights to up to show disk activity above the screw.
  4. Dell Latitude E6320 Hard Drive Replacement, Remove the Drive: step 4, image 1 of 2 Dell Latitude E6320 Hard Drive Replacement, Remove the Drive: step 4, image 2 of 2
    • Find the outdent at the right side of the chassis, and pull it outward to release and slide out the hard drive.
    • You don't need too much force, so don't yank it out fast!
  5. Dell Latitude E6320 Hard Drive Replacement, Drive Caddy: step 5, image 1 of 2 Dell Latitude E6320 Hard Drive Replacement, Drive Caddy: step 5, image 2 of 2
    • Remove the Phillips #00 screw that secures the drive caddy to the hard drive.
    • Make sure to hold the drive firmly so no accidents happen!
  6. Dell Latitude E6320 Hard Drive Replacement: step 6, image 1 of 2 Dell Latitude E6320 Hard Drive Replacement: step 6, image 2 of 2
    • Dislodge the caddy from the drive by lifting the caddy up and wiggling it outwards at the same time.
    • Do not use too much force. Doing so will cause the top mount screw to potentially bend.
To install your new hard drive and reassemble your device, follow these instructions in reverse order.
If you are replacing your exisitng HDD with a SSD, make sure to get a spacer.
Hezekiah Brown
6,169 Reputation
50 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 809
