Dell Latitude E6330 Hard-Drive Replacement
  1. Dell Latitude E6330 Hard-Drive Replacement, Battery: step 1, image 1 of 1
    • Turn off computer by holding down the power button
  2. Dell Latitude E6330 Hard-Drive Replacement: step 2, image 1 of 3 Dell Latitude E6330 Hard-Drive Replacement: step 2, image 2 of 3 Dell Latitude E6330 Hard-Drive Replacement: step 2, image 3 of 3
    • Slide latches out to unlock and remove battery.
  3. Dell Latitude E6330 Hard-Drive Replacement, Hard-Drive: step 3, image 1 of 1
    • Flip the laptop over so the bottom face is facing up.
    • Only follow the battery replacement guide up to removal. You do not need to replace the battery as well if you are replacing the hard-drive. Removal is only done to prevent damage to the laptop.
  4. Dell Latitude E6330 Hard-Drive Replacement: step 4, image 1 of 1
    • Using the Phillips #00, remove the two 2.5mm x 5mm screws located at the front left corner of the laptop.
  5. Dell Latitude E6330 Hard-Drive Replacement: step 5, image 1 of 1
    • Slide the hard drive & caddy out of its slot.
John Donahue
130 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,412
