Dell Latitude E6330 Screen Replacement
  1. Dell Latitude E6330 Screen Replacement, Battery: step 1, image 1 of 1
    • Turn off computer by holding down the power button
  2. Dell Latitude E6330 Screen Replacement: step 2, image 1 of 3 Dell Latitude E6330 Screen Replacement: step 2, image 2 of 3 Dell Latitude E6330 Screen Replacement: step 2, image 3 of 3
    • Slide latches out to unlock and remove battery.
  3. Dell Latitude E6330 Screen Replacement, Screen: step 3, image 1 of 1
    • Open the laptop and unscrew the 2.5 X 3mm screw in the bottom center of screen
  4. Dell Latitude E6330 Screen Replacement: step 4, image 1 of 1
    • Using a spudger, carefully remove of the exterior black frame/cover of the screen
  5. Dell Latitude E6330 Screen Replacement: step 5, image 1 of 1
    • Using a Philips head screw driver, screw the ten surrounding 2.5 X 3mm screws on the frame of the screen
  6. Dell Latitude E6330 Screen Replacement: step 6, image 1 of 1
    • Detach the yellow LCD inverted from the back of the screen
  7. Dell Latitude E6330 Screen Replacement: step 7, image 1 of 1
    • Carefully pull off the screen itself
Brett Murray
399 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 31
All Time: 922
