Dell Latitude E6400 CPU Replacement
  1. Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 1 of 3 Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 2 of 3 Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 3 of 3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 CPU Replacement, Bottom Lid: step 2, image 1 of 2 Dell Latitude E6400 CPU Replacement, Bottom Lid: step 2, image 2 of 2
    • Remove the one 7.5 mm Phillips screw securing the bottom case.
    • Pull the bottom lid towards yourself to remove it.
  3. Dell Latitude E6400 CPU Replacement, Fan: step 3, image 1 of 3 Dell Latitude E6400 CPU Replacement, Fan: step 3, image 2 of 3 Dell Latitude E6400 CPU Replacement, Fan: step 3, image 3 of 3
    • Remove the two 4.8mm Phillips screws securing the fan.
    • Disconnect the fan by pulling power cable straight up.
    • Lift the fan with your finger and slide it out towards the inside of the laptop.
  4. Dell Latitude E6400 CPU Replacement, Heat Sink: step 4, image 1 of 2 Dell Latitude E6400 CPU Replacement, Heat Sink: step 4, image 2 of 2
    • Remove the four Phillips screws securing the heat sink.
    • Using your finger gently lift and remove heat sink .
  5. Dell Latitude E6400 CPU Replacement: step 5, image 1 of 1
    • Gently rotate left the locking screw to release CPU from its socket.
    • Lift the CPU straight up of it's socket.
D. K. Labudek
685 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 321
