Dell Latitude E6400 Hard Drive Replacement
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Hard Drive Replacement: step 2, image 1 of 1
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive: step 5, image 1 of 1
    • After removing the battery, locate and remove the two M3 x 3-mm screws securing the hard drive to the base assembly. Then, slide the hard drive from the base assembly.
  4. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive bezel: step 6, image 1 of 1
    • Next, remove the M3 x 3-mm screw on the hard drive bezel and remove the hard drive bezel. NOTE: Be mindful not to touch the components of the drive. Doing so could damage the drive.
With your replacement hard drive, reassemble your device by performing the instructions above in reverse order.
Aaron Thomas
1,194 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
One Comment
Easy hard drive replacement!
Jeffrey P - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 47
All Time: 1,284
