Dell Latitude E6400 Heatsink Replacement
  1. Dell Latitude E6400 Heatsink Replacement, Heatsink & Thermal Paste: step 1, image 1 of 1
    • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
    • This will release the battery. Just slide the battery away from the computer.
    • Remove all screws and slide the panel off the laptop.
  2. Dell Latitude E6400 Heatsink Replacement: step 2, image 1 of 1
    • Pull the fan cable straight away from its socket.
  3. Dell Latitude E6400 Heatsink Replacement: step 3, image 1 of 2 Dell Latitude E6400 Heatsink Replacement: step 3, image 2 of 2
    • Loosen screw 1
    • Do not completely loosen a screw.
    • Loosen each screw a little bit. Going from 1 then to 2 then to 3 and then to 4. Keep doing this until they are all loose.
    • Loosening one completely with out the other screws loosened may damage the logic board
    • Lift the heatsink up, until it won't rise any farther.
    • Pull the heat sink out.
  4. Dell Latitude E6400 Heatsink Replacement: step 4, image 1 of 3 Dell Latitude E6400 Heatsink Replacement: step 4, image 2 of 3 Dell Latitude E6400 Heatsink Replacement: step 4, image 3 of 3
    • Using cotton swabs, clean off the old thermal paste off the die of the CPU and the heat sink.
    • Use the strongest isopropyl alcohol you can find.
    • You want to dip the cotton swabs into the alcohol and clean off the paste.
    • Keep doing this until the white cotton remains white. this indicates it is as clean as possible.
    • Dry the heat sink and die with another cotton swab. Make sure than none of the carbon fibers are left on the die or copper plating.
  5. Dell Latitude E6400 Heatsink Replacement: step 5, image 1 of 2 Dell Latitude E6400 Heatsink Replacement: step 5, image 2 of 2
    • And screw the screws in securely.
    • You want it tight, but not to tight because you will crack the logic board rendering it useless.
  6. Dell Latitude E6400 Heatsink Replacement: step 6, image 1 of 3 Dell Latitude E6400 Heatsink Replacement: step 6, image 2 of 3 Dell Latitude E6400 Heatsink Replacement: step 6, image 3 of 3
    • Side the back cover on.
    • Screw the screw in.
    • Pop the battery back in.
11 other people completed this guide.
Nicholas Ouimet
3,479 Reputation
12 Guides authored
3 Comments
Followed this guide hoping to reduce the loud fan noise from my E6400. You missed out the important step of applying new thermal paste after removing the old stuff. Also, you don't mention the other two chips under the heatsink (presume the GPU and northbridge/chipset). On mine these had spongy, compressible pads where I would have expected thermal paste or a thermal sticker. I wasn't sure whether to remove these or not, since they are quite thick - it seemed unlikely that normal thermal paste could bridge the gap. After putting everything back together the machine is still very noisy so it seems that the cpu temperature is not causing the high fan speed.
Rory Gamble - Reply
Step 4 shows how to clean the old thermal paste off the processor. The rubber squares are thermal pads. Take care not to rip or damage them, or they will need to be replaced.
Nicholas Ouimet -
Regarding the thermal pads, what replacements would be recommended? While repairing mine I saw that the thermal pad was torn and forgot to get a measure of its thickness.
Keftan - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 17,119
