Dell Latitude E6410 Cooling Fan Replacement
  1. Dell Latitude E6410 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
  2. Dell Latitude E6410 Cooling Fan Replacement: step 2, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement: step 2, image 2 of 2
    • Remove the following 5mm screws.
    • Loosen the middle 5mm screw.
  3. Dell Latitude E6410 Cooling Fan Replacement: step 3, image 1 of 1
    • Remove the back cover by sliding it downwards.
  4. Dell Latitude E6410 Cooling Fan Replacement: step 4, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement: step 4, image 2 of 2
    • Unscrew the following 2mm screws.
    • Remove the fan case.
    • Do not pull hard enough to break the wires connected to the motor.
  5. Dell Latitude E6410 Cooling Fan Replacement: step 5, image 1 of 1
    • Unscrew the 1mm screws on the fan case.
  6. Dell Latitude E6410 Cooling Fan Replacement: step 6, image 1 of 1
    • Remove the fan by pulling it away from the motor.
5 other people completed this guide.
Stephen Tate
889 Reputation
4 Guides authored
Baylor, Team S8-G2, Johnson Fall 2017 Member of Baylor, Team S8-G2, Johnson Fall 2017
BU-JOHNSON-F17S8G2
1 Member
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 2,286
