Dell Latitude E6410 Hard Drive Replacement
Aaron Thomas
Aaron Thomas and 3 other contributors
Last updated on November 15, 2022
8 minutes
Easy
Community-Contributed Guide
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: step 1, image 1 of 3 Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: step 1, image 2 of 3 Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: step 1, image 3 of 3
    • Slide the latches on the battery and remove the battery.
  2. Dell Latitude E6410 Hard Drive Replacement, Remove Hard Drive Screws: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove to the screws that secure the hard drive from the hard drive caddy.
  3. Dell Latitude E6410 Hard Drive Replacement, Remove The Hard Drive: step 3, image 1 of 2 Dell Latitude E6410 Hard Drive Replacement, Remove The Hard Drive: step 3, image 2 of 2
    • Slide the hard drive out of the laptop. DO NOT TOUCH THE COMPONENTS OF THE DRIVE. Doing so could damage the drive. Protect yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
    • Insert your new drive in to the hard drive caddy. Again, make sure you do not touch the components of the drive. After this, perform the steps above in reverse order.
    • After properly reassembling your device, your new hard drive should be installed. Great job.
To reassemble your device, follow these instructions in reverse order and power on your device.
2 other people completed this guide.
Aaron Thomas
1,224 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 2,846
