Dell Latitude E6420 CPU Replacement
  1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: step 1, image 1 of 2 Dell Latitude E6420 CPU Replacement, Rear Panel Removal: step 1, image 2 of 2
    • Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
  2. Dell Latitude E6420 CPU Replacement, CPU: step 2, image 1 of 1
    • Remove the battery by pushing the tabs outward, then removing the battery from the device.
  3. Dell Latitude E6420 CPU Replacement: step 3, image 1 of 1
    • Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
    • Remove the heatsink and fan assembly.
  4. Dell Latitude E6420 CPU Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
  5. Dell Latitude E6420 CPU Replacement: step 5, image 1 of 2 Dell Latitude E6420 CPU Replacement: step 5, image 2 of 2
    • Lift the CPU out of the motherboard assembly.
6 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 38
All Time: 3,197
