Dell Latitude E6420 Fan Replacement
  1. Dell Latitude E6420 Fan Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6420 Fan Replacement, Battery: step 1, image 2 of 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: step 2, image 1 of 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: step 3, image 1 of 2 Dell Latitude E6420 Fan Replacement, CD/DVD Drive: step 3, image 2 of 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: step 4, image 1 of 2 Dell Latitude E6420 Fan Replacement: step 4, image 2 of 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: step 5, image 1 of 2 Dell Latitude E6420 Fan Replacement, Backplate: step 5, image 2 of 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: step 6, image 1 of 2 Dell Latitude E6420 Fan Replacement: step 6, image 2 of 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: step 7, image 1 of 2 Dell Latitude E6420 Fan Replacement, Fan: step 7, image 2 of 2
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: step 8, image 1 of 2 Dell Latitude E6420 Fan Replacement: step 8, image 2 of 2
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: step 9, image 1 of 1
    • Lift the fan out of the laptop.
4 other people completed this guide.
Madysen Eames
1,528 Reputation
7 Guides authored
One Comment
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,162
