Dell Latitude E6430 Keyboard Replacement
  1. Dell Latitude E6430 Keyboard Replacement, Removing the battery: step 1, image 1 of 3 Dell Latitude E6430 Keyboard Replacement, Removing the battery: step 1, image 2 of 3 Dell Latitude E6430 Keyboard Replacement, Removing the battery: step 1, image 3 of 3
    • As always before laying hand on any electronic device we have to remove the battery. Also make sure you haven't connected the power supply.
    • To remove the battery turn the device around and look for the two latches on the left and right side (red rectangles).
    • With the battery removed you may now remove the two screws next to the docking station connector (green circles)
  2. Dell Latitude E6430 Keyboard Replacement, Keyboard frame: step 2, image 1 of 3 Dell Latitude E6430 Keyboard Replacement, Keyboard frame: step 2, image 2 of 3 Dell Latitude E6430 Keyboard Replacement, Keyboard frame: step 2, image 3 of 3
    • Turn around the device and open the screen. Before the keyboard may be removed you have to remove the frame around it.
    • Use a spudger between the c-cover and the frame. Begin at the top and don't be shy as the frame is quite sturdy and flexible.
    • With the frame removed it should look like in the last photo.
  3. Dell Latitude E6430 Keyboard Replacement, Keyboard removal: step 3, image 1 of 3 Dell Latitude E6430 Keyboard Replacement, Keyboard removal: step 3, image 2 of 3 Dell Latitude E6430 Keyboard Replacement, Keyboard removal: step 3, image 3 of 3
    • There are four screws which have to be unscrewed to proceed.
    • Lift up the keyboard carefully as it is still connected by a ribbon cable. (green rectangle)
    • To be able to pull out the ribbon cable you have to lift the plastic lever on top in the direction of the orange arrow.
  4. Dell Latitude E6430 Keyboard Replacement, Finished!: step 4, image 1 of 1
    • Congratulations. You have successfully removed the keyboard.
    • You may now replace it with a spare.
    • With the keyboard removed you could remove dust and crumbs accumulated in your notebook.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 43
All Time: 1,080
