Dell Latitude E6440 CMOS/Coin Cell Battery Replacement
    • Make sure all external components are removed from the device( ie. USBs, power cords, network cables, headphones, etc.) and the device is powered off.
  1. Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove Battery: step 2, image 1 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove Battery: step 2, image 2 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove Battery: step 2, image 3 of 3
    • Slide the battery release latches into the unlock position. Then, rotate the outer edge of the battery upward and remove from the system.
  2. Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove the access panel: step 3, image 1 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove the access panel: step 3, image 2 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Remove the access panel: step 3, image 3 of 3
    • After removing the battery, remove the screws securing the access panel in place. Then, lift the top edge of the access panel upward and remove the access panel.
  3. Dell Latitude E6440 CMOS/Coin Cell Battery Replacement: step 4, image 1 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement: step 4, image 2 of 3 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement: step 4, image 3 of 3
    • After removing the access panel, locate the CMOS battery in the mid-left section of the panel. Careful disconnect the CMOS battery cable from the system, then pry the CMOS battery upward to remove. NOTE: Remember not to touch any of the system components when the panel is open, as doing so could damage your system via electrostatic discharge.
  4. Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Replace CMOS Battery: step 5, image 1 of 1
    • Using your replacement battery, carefully connect the CMOS battery to the system.
  5. Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Reassemble your device.: step 6, image 1 of 2 Dell Latitude E6440 CMOS/Coin Cell Battery Replacement, Reassemble your device.: step 6, image 2 of 2
    • Now that you have replaced your CMOS battery, reassemble your device by completing all previous steps in reverse order.
Aaron Thomas
1,194 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
One Comment
What is the problem with my Dell latitude E6440, it starts up but the screen won't show anything and how can I fix it?
Nik - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,218
