Dell Latitude E6440 Memory Replacement
    • Make sure all external components are removed from the device( ie. USBs, power cords, network cables, headphones, etc.) and the device is powered off.
  1. Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 1 of 3 Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 2 of 3 Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 3 of 3
    • Slide the battery release latches into the unlock position. Then, rotate the outer edge of the battery upward and remove from the system.
  2. Dell Latitude E6440 Memory  Replacement, Remove base cover: step 3, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Remove base cover: step 3, image 2 of 2
    • After removing the battery, remove the screws that secure the base cover to the computer, then lift the base cover and remove it from the computer.
  3. Dell Latitude E6440 Memory  Replacement, Remove memory: step 4, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Remove memory: step 4, image 2 of 2
    • Pry the securing clips away from the memory module until it pops-up and remove the memory module from its connector on the system board.
  4. Dell Latitude E6440 Memory  Replacement, Install new memory: step 5, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Install new memory: step 5, image 2 of 2
    • With your new memory, insert the memory into the memory socket, then press the securing clips to secure the memory module to the system board.
Reassemble your device by performing the instructions above in reverse order.
Aaron Thomas
1,251 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 787
