Dell Latitude E6510 Heat Sink Replacement
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: step 1, image 1 of 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: step 1, image 2 of 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: step 1, image 3 of 3
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: step 2, image 1 of 3 Dell Latitude E6510  Heat Sink Replacement: step 2, image 2 of 3 Dell Latitude E6510  Heat Sink Replacement: step 2, image 3 of 3
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: step 3, image 1 of 3 Dell Latitude E6510  Heat Sink Replacement: step 3, image 2 of 3 Dell Latitude E6510  Heat Sink Replacement: step 3, image 3 of 3
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: step 4, image 1 of 3 Dell Latitude E6510  Heat Sink Replacement: step 4, image 2 of 3 Dell Latitude E6510  Heat Sink Replacement: step 4, image 3 of 3
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: step 5, image 1 of 1
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: step 6, image 1 of 3 Dell Latitude E6510  Heat Sink Replacement: step 6, image 2 of 3 Dell Latitude E6510  Heat Sink Replacement: step 6, image 3 of 3
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 955
