Dell Latitude E6510 Hard Drive Replacement
  1. Dell Latitude E6510 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Unlock the two latches on the back by sliding them inwards.
  2. Dell Latitude E6510 Hard Drive Replacement: step 2, image 1 of 2 Dell Latitude E6510 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the battery out from the laptop.
  3. Dell Latitude E6510 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Latitude E6510 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • After removing the battery, unscrew the four 3 mm screws on the back plate using a Phillips #1 screwdriver.
    • The back plate does not need to be removed. Removed only for a clear view.
  4. Dell Latitude E6510 Hard Drive Replacement: step 4, image 1 of 2 Dell Latitude E6510 Hard Drive Replacement: step 4, image 2 of 2
    • The hard drive should slide out of the laptop. However, if not, use a spudger to pry the hard drive out of the laptop.
Kolin Doyle
500 Reputation
4 Guides authored
Baylor, Team S8-G4, Johnson Fall 2017 Member of Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 Member
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,980
