Dell Latitude E6510 RAM Replacement
  1. Dell Latitude E6510 RAM Replacement, RAM: step 1, image 1 of 1
    • Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
  2. Dell Latitude E6510 RAM Replacement: step 2, image 1 of 1
    • Unclasp and pull the memory card up.
    • Be careful when unclasping and releasing the memory card. Clasps are fragile.
3 other people completed this guide.
Kolin Doyle
500 Reputation
4 Guides authored
Baylor, Team S8-G4, Johnson Fall 2017 Member of Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 Member
4 Guides authored
One Comment
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
Brian Barlow - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,989
