Dell Latitude E6510 RAM Replacement
  1. Dell Latitude E6510 RAM Replacement, RAM: step 1, image 1 of 3 Dell Latitude E6510 RAM Replacement, RAM: step 1, image 2 of 3 Dell Latitude E6510 RAM Replacement, RAM: step 1, image 3 of 3
    • Orient the laptop so that the bottom is facing up towards you.
    • Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
    • Slide the battery out and separate it from the laptop.
  2. Dell Latitude E6510 RAM Replacement: step 2, image 1 of 3 Dell Latitude E6510 RAM Replacement: step 2, image 2 of 3 Dell Latitude E6510 RAM Replacement: step 2, image 3 of 3
    • Remove the 5 screws from the back panel with a type 0 Phillips head.
    • Pull the panel towards you in a slightly upwards motion.
    • Remove the panel from the laptop and set it aside.
  3. Dell Latitude E6510 RAM Replacement: step 3, image 1 of 3 Dell Latitude E6510 RAM Replacement: step 3, image 2 of 3 Dell Latitude E6510 RAM Replacement: step 3, image 3 of 3
    • Locate the RAM sticks in the laptop.
    • Using your fingers, disconnect the prongs connected to the RAM sticks.
    • Gently remove the RAM from the port.
    • Repeat the first three steps to remove the second RAM stick.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 231
