Dell Latitude E6520 Keyboard Replacement
  1. Dell Latitude E6520 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6520 Keyboard Replacement, Battery: step 1, image 2 of 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 Keyboard Replacement: step 2, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 2, image 2 of 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: step 3, image 1 of 2 Dell Latitude E6520 Keyboard Replacement, Bottom Cover: step 3, image 2 of 2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 Keyboard Replacement: step 4, image 1 of 1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 3 of 3
    • Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
  6. Dell Latitude E6520 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 6, image 2 of 2
    • Remove the six 3.63 mm JIS #0 screws holding the keyboard in place.
  7. Dell Latitude E6520 Keyboard Replacement: step 7, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 7, image 2 of 2
    • Lift the keypad up from the bottom.
    • Rest the keypad on the LCD screen for easy access during the next step.
  8. Dell Latitude E6520 Keyboard Replacement: step 8, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 8, image 2 of 2
    • Peel back the tape holding the ribbon connector.
    • Disconnect the ribbon and the keyboard will be free from the laptop.
Alec Weiss
800 Reputation
8 Guides authored
IUPUI, Team S2-G2, Baechle Fall 2018 Member of IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Members
8 Guides authored
One Comment
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
khalidaafghany - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,872
