Dell Latitude E6520 LCD Screen Replacement
  1. Dell Latitude E6520 LCD Screen Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6520 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 LCD Screen Replacement: step 2, image 1 of 2 Dell Latitude E6520 LCD Screen Replacement: step 2, image 2 of 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 LCD Screen Replacement, LCD Screen: step 3, image 1 of 1
    • Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
  4. Dell Latitude E6520 LCD Screen Replacement: step 4, image 1 of 2 Dell Latitude E6520 LCD Screen Replacement: step 4, image 2 of 2
    • Remove the six 5.75 mm JIS #0 screws that hold the LCD screen to the cover.
  5. Dell Latitude E6520 LCD Screen Replacement: step 5, image 1 of 2 Dell Latitude E6520 LCD Screen Replacement: step 5, image 2 of 2
    • Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable.
Alec Weiss
800 Reputation
8 Guides authored
IUPUI, Team S2-G2, Baechle Fall 2018 Member of IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,200
