Dell Latitude E6520 WLAN Adaptor Card Replacement
Alec Weiss
Alec Weiss and 2 other contributors
Last updated on December 19, 2018
5 minutes
Moderate
Introduction
Go to step 1
The WLAN Adapter Card is what allows the computer to connect to Wi-Fi.
The WLAN Adapter Card is connected to the laptop by 2 J0 PH screws with a head size of 4.44 mm and a length of 3.67 mm.
  1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: step 1, image 2 of 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 WLAN Adaptor Card Replacement: step 2, image 1 of 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: step 2, image 2 of 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: step 3, image 1 of 2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: step 3, image 2 of 2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 WLAN Adaptor Card Replacement: step 4, image 1 of 1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 WLAN Adaptor Card Replacement, WLAN Adapter Card: step 5, image 1 of 1
    • Gently pull the two wires connected to the WLAN Adapter Card.
  6. Dell Latitude E6520 WLAN Adaptor Card Replacement: step 6, image 1 of 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: step 6, image 2 of 2
    • Remove the two electrode connectors.
    • Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • The WLAN Adapter Card will pop up once the screws are taken out.
  7. Dell Latitude E6520 WLAN Adaptor Card Replacement: step 7, image 1 of 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: step 7, image 2 of 2
    • Pull WLAN Adapter Card to remove it from the laptop.
Alec Weiss
800 Reputation
8 Guides authored
IUPUI, Team S2-G2, Baechle Fall 2018 Member of IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 937
