Dell Latitude E6530 Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell Latitude E6530  Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Open up the Dell Latitude E6530.
  2. Dell Latitude E6530  Motherboard Replacement: step 2, image 1 of 1
    • Use the spludger to lift the grey casing off the Dell Latitude E6530 keyboard.
  3. Dell Latitude E6530  Motherboard Replacement: step 3, image 1 of 2 Dell Latitude E6530  Motherboard Replacement: step 3, image 2 of 2
    • Using a Phillips #1 Screwdriver, unscrew the button panel.
    • Life the button panel out of the Dell Latitude E6530.
  4. Dell Latitude E6530  Motherboard Replacement: step 4, image 1 of 1
    • Flip the computer onto it's back.
    • Remove the back panel.
    • Using a 1mm Philips Head Screwdriver, remove the screws indicated in the image.
  5. Dell Latitude E6530  Motherboard Replacement: step 5, image 1 of 1
    • Use a spludger to remove the keyboard.
  6. Dell Latitude E6530  Motherboard Replacement: step 6, image 1 of 1
    • Lift off the final casing and remove the motherboard.
To reassemble your device, follow these instructions in reverse order. If problem persists refer to troubleshooting guide and additional links.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 25
