Dell Latitude E6530 Fan & Heatsink Replacement
  1. Dell Latitude E6530 Fan & Heatsink Replacement, Battery: step 1, image 1 of 1
    • Flip over the laptop.
  2. Dell Latitude E6530 Fan & Heatsink Replacement: step 2, image 1 of 1
    • Pull back the 2 battery tabs which are to the left and the right of the battery.
  3. Dell Latitude E6530 Fan & Heatsink Replacement: step 3, image 1 of 1
    • Remove the battery from the laptop.
  4. Dell Latitude E6530 Fan & Heatsink Replacement, Bottom Cover: step 4, image 1 of 1
    • Remove the 4 Philips #0 screws from the laptop.
  5. Dell Latitude E6530 Fan & Heatsink Replacement: step 5, image 1 of 1
    • Remove the bottom cover from the laptop.
  6. Dell Latitude E6530 Fan & Heatsink Replacement, Heatsink: step 6, image 1 of 1
    • Remove the fan connector.
  7. Dell Latitude E6530 Fan & Heatsink Replacement: step 7, image 1 of 1
    • Remove the 4 Philips #1 screws on the heatsink.
  8. Dell Latitude E6530 Fan & Heatsink Replacement: step 8, image 1 of 1
    • Remove the Fan+Heatsink assembly.
  9. Dell Latitude E6530 Fan & Heatsink Replacement: step 9, image 1 of 2 Dell Latitude E6530 Fan & Heatsink Replacement: step 9, image 2 of 2
    • Use a paper towel or alcohol swab to clean the thermal paste from the heatsink & CPU.
To reassemble your device, follow these instructions in reverse order. Remember to apply the thermal paste on the CPU!
3 other people completed this guide.
Ella
2,221 Reputation
10 Guides authored
2 Comments
The Amazon link above no longer works (404).
It's important to note that there are two different heatsinks depending on the type of GPU equipped in the system
* Lattitude E6530 with Intel UMA Integrated Video uses Dell 2MK5J heatsink / fan assembly as shown in the guide
* Those with Discrete Nvidia use Dell M2CFG with can be differentiated by the two heat sinks and two copper heat pipes.
Dell doesn't list these parts for sale (Jan 2023) though used ones are listed on eBay.
Mike Verstegen - Reply
Yes, I just saw one for sale on eBay (the M2CFG)
bk_qb - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 2,254
