Dell Latitude E6530 Fan Replacement Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell Latitude E6530 Fan Replacement Replacement, Fan Replacement: step 1, image 1 of 1
    • Begin by flipping the computer over to the bottom.
    • Using a spudger, insert it into the corner of the back panel and move it around the panel.
    • Remove the back panel completely.
  2. Dell Latitude E6530 Fan Replacement Replacement: step 2, image 1 of 2 Dell Latitude E6530 Fan Replacement Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws.
  3. Dell Latitude E6530 Fan Replacement Replacement: step 3, image 1 of 1
    • Unhook the cord connecting the fan to the computer.
    • Carefully pull the fan out of the computer.
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links if problem persists.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 36
