Dell Latitude E6530 Motherboard Replacement
  1. Dell Latitude E6530 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Pull back the 2 battery tabs.
  2. Dell Latitude E6530 Motherboard Replacement: step 2, image 1 of 1
    • Pull out the battery.
  3. Dell Latitude E6530 Motherboard Replacement, DVD Drive: step 3, image 1 of 1
    • Push the button next to the DVD drive.
  4. Dell Latitude E6530 Motherboard Replacement: step 4, image 1 of 1
    • Pull out the DVD Drive.
  5. Dell Latitude E6530 Motherboard Replacement, Hard Drive: step 5, image 1 of 1
    • Undo the 2 Phillips #00 screws.
  6. Dell Latitude E6530 Motherboard Replacement: step 6, image 1 of 1
    • Pull out the hard drive.
  7. Dell Latitude E6530 Motherboard Replacement, Back Cover: step 7, image 1 of 1
    • Remove the 5 Phillips #00 screws.
  8. Dell Latitude E6530 Motherboard Replacement: step 8, image 1 of 1
    • Remove the back cover.
  9. Dell Latitude E6530 Motherboard Replacement, Keyboard: step 9, image 1 of 2 Dell Latitude E6530 Motherboard Replacement, Keyboard: step 9, image 2 of 2
    • Flip over and open the laptop.
  10. Dell Latitude E6530 Motherboard Replacement: step 10, image 1 of 3 Dell Latitude E6530 Motherboard Replacement: step 10, image 2 of 3 Dell Latitude E6530 Motherboard Replacement: step 10, image 3 of 3
    • Use your fingernail or opening tool to remove the keyboard bezel.
  11. Dell Latitude E6530 Motherboard Replacement: step 11, image 1 of 1
    • Remove the 3 Phillips #00 screws.
  12. Dell Latitude E6530 Motherboard Replacement: step 12, image 1 of 1
    • Carefully remove the keyboard.
    • Do not lift up the keyboard too much, as it is still attached via a ribbon cable.
  13. Dell Latitude E6530 Motherboard Replacement: step 13, image 1 of 2 Dell Latitude E6530 Motherboard Replacement: step 13, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to lift up the ribbon cable lock.
    • Use a pair of tweezers or your finger to remove the keyboard ribbon cable
    • Set the keyboard aside.
  14. Dell Latitude E6530 Motherboard Replacement, Palmrest: step 14, image 1 of 1
    • Remove the 10 Phillips #00 screws.
  15. Dell Latitude E6530 Motherboard Replacement: step 15, image 1 of 1
    • Remove the 8 Phillips #00 screws,
  16. Dell Latitude E6530 Motherboard Replacement: step 16, image 1 of 1
    • Use a pair of tweezers to remove the trackpad ribbon cable.
  17. Dell Latitude E6530 Motherboard Replacement: step 17, image 1 of 1
    • Use a pair of tweezers to remove the ribbon cable for the lights and buttons.
  18. Dell Latitude E6530 Motherboard Replacement: step 18, image 1 of 1
    • Lift off the laptop's palmrest.
  19. Dell Latitude E6530 Motherboard Replacement, Wi-Fi and cellular cards: step 19, image 1 of 2 Dell Latitude E6530 Motherboard Replacement, Wi-Fi and cellular cards: step 19, image 2 of 2
    • Close and flip over the laptop.
    • Remove the antenna cables and screws from the Wi-Fi card and the cellular card.
  20. Dell Latitude E6530 Motherboard Replacement: step 20, image 1 of 2 Dell Latitude E6530 Motherboard Replacement: step 20, image 2 of 2
    • Remove the Wi-Fi and cellular cards.
  21. Dell Latitude E6530 Motherboard Replacement, CMOS battery: step 21, image 1 of 1
    • Disconnect and remove the CMOS battery.
  22. Dell Latitude E6530 Motherboard Replacement, Heatsink: step 22, image 1 of 1
    • Remove the 4 heatsink screws.
  23. Dell Latitude E6530 Motherboard Replacement: step 23, image 1 of 2 Dell Latitude E6530 Motherboard Replacement: step 23, image 2 of 2
    • Disconnect and remove the heatsink.
    • Make sure you have thermal paste before doing this! You will need to reapply the CPU's thermal paste.
  24. Dell Latitude E6530 Motherboard Replacement, CPU: step 24, image 1 of 1
    • Use a knife or flathead screwdriver to turn the CPU lock counter-clockwise.
    • Remember to turn the CPU lock clockwise when reassembling the laptop! If you don't, the system will not turn on.
  25. Dell Latitude E6530 Motherboard Replacement: step 25, image 1 of 1
    • Remove the CPU
    • Be VERY CAREFUL to not bend ANY pins on the CPU.
  26. Dell Latitude E6530 Motherboard Replacement, Display Cable: step 26, image 1 of 2 Dell Latitude E6530 Motherboard Replacement, Display Cable: step 26, image 2 of 2
    • Unscrew and remove the bracket.
  27. Dell Latitude E6530 Motherboard Replacement: step 27, image 1 of 2 Dell Latitude E6530 Motherboard Replacement: step 27, image 2 of 2
    • Disconnect the display cables.
  28. Dell Latitude E6530 Motherboard Replacement, Motherboard: step 28, image 1 of 3 Dell Latitude E6530 Motherboard Replacement, Motherboard: step 28, image 2 of 3 Dell Latitude E6530 Motherboard Replacement, Motherboard: step 28, image 3 of 3
    • Remove the 2 motherboard cables.
  29. Dell Latitude E6530 Motherboard Replacement: step 29, image 1 of 1
    • Remove the 5 motherboard screws.
  30. Dell Latitude E6530 Motherboard Replacement: step 30, image 1 of 2 Dell Latitude E6530 Motherboard Replacement: step 30, image 2 of 2
    • Remove the 2 bracket screws.
    • Remove the bracket.
  31. Dell Latitude E6530 Motherboard Replacement: step 31, image 1 of 1
    • Remove the motherboard.
3 other people completed this guide.
Ella
2,221 Reputation
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 24
All Time: 829
