Dell Latitude E7270 Motherboard Removal
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: step 1, image 1 of 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: step 2, image 1 of 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: step 3, image 1 of 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: step 4, image 1 of 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: step 5, image 1 of 2 Dell Latitude E7270 Motherboard Removal: step 5, image 2 of 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: step 6, image 1 of 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: step 7, image 1 of 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: step 7, image 2 of 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: step 7, image 3 of 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: step 8, image 1 of 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: step 9, image 1 of 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: step 10, image 1 of 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: step 10, image 2 of 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: step 10, image 3 of 3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: step 11, image 1 of 1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 42
All Time: 3,087
