Dell Latitude E7270 Solid State Drive Replacement
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: step 1, image 1 of 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: step 2, image 1 of 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Solid State Drive Replacement: step 3, image 1 of 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: step 4, image 1 of 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Solid State Drive Replacement: step 5, image 1 of 2 Dell Latitude E7270 Solid State Drive Replacement: step 5, image 2 of 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: step 6, image 1 of 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: step 7, image 1 of 1
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: step 8, image 1 of 1
    • Slide the SSD of its socket.
2 other people completed this guide.
One Comment
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - Reply
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 63
All Time: 4,458
