Dell Latitude E7440 CMOS Battery Replacement
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: step 1, image 1 of 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: step 2, image 1 of 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: step 2, image 2 of 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: step 2, image 3 of 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: step 3, image 1 of 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: step 4, image 1 of 2 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: step 4, image 2 of 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: step 5, image 1 of 2 Dell Latitude E7440 CMOS Battery Replacement: step 5, image 2 of 2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: step 6, image 1 of 3 Dell Latitude E7440 CMOS Battery Replacement: step 6, image 2 of 3 Dell Latitude E7440 CMOS Battery Replacement: step 6, image 3 of 3
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: step 7, image 1 of 1
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
6 other people completed this guide.
Akash Kedia
1,397 Reputation
5 Guides authored
Cal Poly, Team S2-G5, White Winter 2019 Member of Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Members
5 Guides authored
2 Comments
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - Reply
@jess13j, battery is a CR2032 coin cell.
senzog - Reply
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 104
All Time: 13,312
