Dell Latitude E7440 Keyboard Replacement
Sheetal Prasanna
Sheetal Prasanna and 3 other contributors
Last updated on December 19, 2019
35 minutes
Moderate
Introduction
Go to step 1
If the keyboard of your Dell Latitude E7440 is damaged in any form, use this guide to replace the trackpad.
The keyboard is the main input device used in operating the laptop. A damaged or worn out keyboard or a keyboard with missing keys can be a hindrance while using the laptop.
Before using this guide, clean the keyboard using a soft cloth so that it is free of debris.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 2, image 3 of 3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: step 3, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 3, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 3, image 3 of 3
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Dell Latitude E7440 Keyboard Replacement: step 4, image 1 of 1
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude E7440 Keyboard Replacement: step 5, image 2 of 2
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: step 6, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 6, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 6, image 3 of 3
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
6 other people completed this guide.
Sheetal Prasanna
649 Reputation
3 Guides authored
IUPUI, Team S1-G1, Stella Fall 2019 Member of IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Members
3 Guides authored
2 Comments
for step three i would add “ the cables to be removed are under a type of flap/cover”. I don’t know if we have to be specific on what tools we used. If we do have to be specific than we will just add them. Other than that great work!
Oscar Aca - Reply
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
Jamie O'Hare - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 43
All Time: 5,439
