Dell Latitude E7450 Memory (RAM) Replacement
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Remove battery and base cover from the computer.
  1. Dell Latitude E7450 Memory (RAM) Replacement, Open retention clips: step 2, image 1 of 1
    • Open the retention clips away from the memory chip.
  2. Dell Latitude E7450 Memory (RAM) Replacement, Remove memory chip: step 3, image 1 of 1
    • Remove the memory chip from the computer.
    • Put a new memory chip in the memory socket.
    • Push the memory chip until the clips lock it. If a second memory chip needs to be installed, repeat steps 1 through 6.
    • Replace the pre-removal parts in descending order.
    • Install the battery and base cover back on the computer.
Hezekiah Brown
6,277 Reputation
49 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,516
