Dell Latitude E7470 SSD Replacement
Hyperion
Hyperion and 2 other contributors
Last updated on January 21, 2021
15 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
Replacing the internal m.2 SSD of a Dell Latitude E7470. You can only choose a 2280 m.2 SSD, the other sizes are not compatible with this PC.
  1. Dell Latitude E7470 SSD Replacement, Open cover: step 1, image 1 of 3 Dell Latitude E7470 SSD Replacement, Open cover: step 1, image 2 of 3 Dell Latitude E7470 SSD Replacement, Open cover: step 1, image 3 of 3
    • Begin by removing the 8 screws circled in red on the photo opposite with a Philips # 0 screwdriver.
    • Next, using the iFixit Opening Picks, lift the cover up from the dock connector. Unclip it gently.
  2. Dell Latitude E7470 SSD Replacement, Changing the SSD: step 2, image 1 of 3 Dell Latitude E7470 SSD Replacement, Changing the SSD: step 2, image 2 of 3 Dell Latitude E7470 SSD Replacement, Changing the SSD: step 2, image 3 of 3
    • After removing the cover, the SSD slot is on the bottom right, right next to the battery.
    • Make sure you have grounded yourself before you start handling. There is a huge risk of damaging components. Use an antistatic wrist strap.
    • To remove the SSD, simply remove the single screw that holds it. Lift the SSD to a 30-degree angle and pull it from its slot.
To reassemble your device, follow the instructions in reverse order.
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Hyperion
2,004 Reputation
3 Guides authored
8 Comments
Does the M.2 interface in this board support NVMe M.2 SSD’s?
Kinetik - Reply
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
Luke Johnson -
It’s not working for me with Kingston nvme NV1
Ravi Bhargava - Reply
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Mike Heiss - Reply
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Past 24 Hours: 6
Past 7 Days: 62
Past 30 Days: 190
All Time: 20,904
