Introduction
If you are unable to hear any sound coming from your device first check the sound settings to ensure your volume is not set to mute. If the volume is turned up there may be dirt clogging the speaker. To remove dirt you can use a cotton swab or tooth pick to clean the area. If you still cannot hear sound coming from the device you will need to replace your Tablet's speakers. Follow the steps on this guide to replace the speaker on your device
Using your hands or a plastic opening tool, disconnect the white speaker connector from its socket near the bottom of the motherboard.
