Dell Latitude X300 RAM Replacement
  1. Dell Latitude X300 RAM Replacement, RAM: step 1, image 1 of 2 Dell Latitude X300 RAM Replacement, RAM: step 1, image 2 of 2
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Dell Latitude X300 RAM Replacement: step 2, image 1 of 1
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Dell Latitude X300 RAM Replacement: step 3, image 1 of 1
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Dell Latitude X300 RAM Replacement: step 4, image 1 of 1
    • Insert the new memory at 45 degree angle.
  5. Dell Latitude X300 RAM Replacement: step 5, image 1 of 1
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
23 Reputation
2 Guides authored
Cal Poly, Team 11-20, Maness Winter 2012 Member of Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,235
