Dell Latitude X300 Screen Replacement
  1. Dell Latitude X300 Screen Replacement, Screen: step 1, image 1 of 1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: step 2, image 1 of 2 Dell Latitude X300 Screen Replacement: step 2, image 2 of 2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: step 3, image 1 of 1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: step 4, image 1 of 1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: step 5, image 1 of 2 Dell Latitude X300 Screen Replacement: step 5, image 2 of 2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
3 other people completed this guide.
Jacob
9 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 730
