Dell OptiPlex FX170 RAM Replacement
  1. Dell OptiPlex FX170 RAM  Replacement, Case: step 1, image 1 of 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 RAM  Replacement: step 2, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement: step 2, image 2 of 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 RAM  Replacement: step 3, image 1 of 3 Dell OptiPlex FX170 RAM  Replacement: step 3, image 2 of 3 Dell OptiPlex FX170 RAM  Replacement: step 3, image 3 of 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 RAM  Replacement: step 4, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement: step 4, image 2 of 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: step 5, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement, RAM: step 5, image 2 of 2
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 RAM  Replacement: step 6, image 1 of 1
    • Lift and pull out the RAM.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,523
