You're viewing a previously published version of this guide.  View latest version
Older Newer
Dell OptiPlex GX260 Motherboard Replacement
Kevin Schapansky
Kevin Schapansky and 10 other contributors
Last updated on August 22, 2019
30 minutes
Moderate
Tools
iFixit earns commission when you buy through these links.
  1. Dell OptiPlex GX260 Motherboard Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement, Case: step 1, image 2 of 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Motherboard Replacement, Main Fan: step 2, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement, Main Fan: step 2, image 2 of 2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Motherboard Replacement: step 3, image 1 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 3, image 2 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 3, image 3 of 3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
  4. Dell OptiPlex GX260 Motherboard Replacement, RAM: step 4, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement, RAM: step 4, image 2 of 2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
  5. Dell OptiPlex GX260 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Disconnect the ATX power cable to the motherboard.
    • Disconnect the P4 12V(4x2) power cable from the motherboard.
  6. Dell OptiPlex GX260 Motherboard Replacement: step 6, image 1 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 6, image 2 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 6, image 3 of 3
    • Disconnect the front panel ribbon cable by gently pulling it straight up.
    • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
    • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  7. Dell OptiPlex GX260 Motherboard Replacement: step 7, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement: step 7, image 2 of 2
    • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
    • Disconnect the optical drive audio cable connector from the motherboard.
    • Disconnect the audio input/output cable from the motherboard.
  8. Dell OptiPlex GX260 Motherboard Replacement: step 8, image 1 of 2 Dell OptiPlex GX260 Motherboard Replacement: step 8, image 2 of 2
    • Lift the metal tab near the right corner of the motherboard.
    • Pull the green tab toward the front of the PC to release the motherboard.
    • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
  9. Dell OptiPlex GX260 Motherboard Replacement: step 9, image 1 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 9, image 2 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 9, image 3 of 3
    • Stand the motherboard up as shown.
    • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
  10. Dell OptiPlex GX260 Motherboard Replacement: step 10, image 1 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 10, image 2 of 3 Dell OptiPlex GX260 Motherboard Replacement: step 10, image 3 of 3
    • Remove the screw at the rear of the motherboard.
    • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
    • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
Kevin Schapansky
1,478 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
27 Guides authored
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 63
All Time: 39,204
