Dell OptiPlex GX260 Optical Drive Replacement
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 Optical Drive Replacement, Case: step 1, image 2 of 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: step 2, image 1 of 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: step 2, image 2 of 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: step 2, image 3 of 3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: step 3, image 1 of 1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
5 other people completed this guide.
Kevin Schapansky
1,466 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 8,866
