Dell Optiplex 745 Small Form Factor Audio Components Replacement
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: step 1, image 1 of 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: step 1, image 2 of 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: step 2, image 1 of 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: step 2, image 2 of 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: step 3, image 1 of 1
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: step 4, image 1 of 1
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: step 5, image 1 of 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: step 5, image 2 of 2
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
Jeremy Nicholas
228 Reputation
2 Guides authored
USF Tampa, Team S5-G5, Walkup Fall 2017 Member of USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,171
