Dell Optiplex 745 Small Form Factor Optical Drive Replacement
  1. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: step 1, image 1 of 2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: step 1, image 2 of 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Optical Drive Replacement: step 2, image 1 of 2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement: step 2, image 2 of 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: step 3, image 1 of 2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: step 3, image 2 of 2
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: step 4, image 1 of 2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: step 4, image 2 of 2
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
9 other people completed this guide.
Tyler Whalen
835 Reputation
3 Guides authored
Cal Poly, Team 13-10, Forte Fall 2014 Member of Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 2,003
