Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: step 1, image 1 of 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: step 1, image 2 of 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: step 1, image 3 of 3
    • Remove the side panel/cover
    • Pull the slide at the top back.
    • This releases the panel, and it can be removed easily.
  2. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: step 2, image 1 of 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: step 2, image 2 of 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: step 2, image 3 of 3
    • Remove the back cover.
    • Unscrew the 3 screws at the back, next to the power cable slot.
    • Pull along the sides of the cover bit by bit to remove each holder from its respective slot
  3. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Rear Audio Jack: step 3, image 1 of 1
    • Upon opening the desktop, locate the rear audio jacks.
  4. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement: step 4, image 1 of 1
    • Once located, identify the soldering points that connect the audio jacks to the motherboard.
    • There is another location you cannot see in the picture which is a part of the rectangular pattern.
    • Gently apply the soldering iron to these points to loosen the hold on the audio jacks.
    • Applying the soldering iron for extended periods of time will damage your device. So it is best to cycle from point to point, slowly trying to remove the audio jacks little by little.
Jeremy Nicholas
228 Reputation
2 Guides authored
USF Tampa, Team S5-G5, Walkup Fall 2017 Member of USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 345
