Dell Optiplex GX620 Hard Drive
  1. Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: step 1, image 2 of 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Hard Drive: step 2, image 1 of 2 Dell Optiplex GX620 Hard Drive: step 2, image 2 of 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Hard Drive, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: step 4, image 1 of 3 Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: step 4, image 2 of 3 Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: step 4, image 3 of 3
    • Remove the power and SATA data cables.
    • SATA power
    • SATA data
  5. Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: step 5, image 1 of 3 Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: step 5, image 2 of 3 Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: step 5, image 3 of 3
    • Pull the two tabs on the hard drive and pull up
  6. Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: step 6, image 1 of 3 Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: step 6, image 2 of 3 Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: step 6, image 3 of 3
    • Now take the tray off of the hard drive.
2 other people completed this guide.
Padraic Hoselton
4,270 Reputation
12 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,373
