Dell Optiplex SX280 Upper Fan Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Upper Fan Replacement: step 2, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Upper Fan Replacement: step 3, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: step 4, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: step 4, image 2 of 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  5. Dell Optiplex SX280 Upper Fan Replacement: step 5, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 5, image 2 of 2
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  6. Dell Optiplex SX280 Upper Fan Replacement: step 6, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 6, image 2 of 2
    • Press on the blue release tab and pull the upper fan out of the computer.
Wyatt
784 Reputation
6 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 8
All Time: 1,875
