Dell Photo Printer 720 Encoder Strip Replacement
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 3 of 3
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 3 of 3
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: step 3, image 1 of 2 Dell Photo Printer 720 Encoder Strip Replacement: step 3, image 2 of 2
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 3 of 3
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
Megan Lawrence
534 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 43
All Time: 824
