Dell Precision 5510 Fans Replacement
  1. Dell Precision 5510 Fans Replacement, Base Cover: step 1, image 1 of 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Fans Replacement: step 2, image 1 of 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Fans Replacement, Fans: step 3, image 1 of 2 Dell Precision 5510 Fans Replacement, Fans: step 3, image 2 of 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Fans Replacement: step 4, image 1 of 2 Dell Precision 5510 Fans Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Fans Replacement: step 5, image 1 of 2 Dell Precision 5510 Fans Replacement: step 5, image 2 of 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Amelia Andrews
97 Reputation
1 Guide authored
IUPUI, Team 2-1, Harley Spring 2022 Member of IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 829
