Dell Precision 5510 Keyboard Replacement
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: step 1, image 1 of 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: step 2, image 1 of 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: step 3, image 1 of 2 Dell Precision 5510 Keyboard Replacement, Fans: step 3, image 2 of 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: step 4, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: step 5, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 5, image 2 of 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: step 6, image 1 of 2 Dell Precision 5510 Keyboard Replacement, Battery: step 6, image 2 of 2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: step 7, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 7, image 2 of 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: step 8, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 8, image 2 of 2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: step 9, image 1 of 1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: step 10, image 1 of 1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: step 11, image 1 of 1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: step 12, image 1 of 1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: step 13, image 1 of 1
    • Pull keyboard out and replace.
Colin Hunter
121 Reputation
1 Guide authored
IUPUI, Team 2-1, Harley Spring 2022 Member of IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Members
4 Guides authored
1 Guide Comment
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,771
