Dell Precision 5520 Hard Drive Replacement
  1. Dell Precision 5520 Hard Drive Replacement, Base Cover: step 1, image 1 of 2 Dell Precision 5520 Hard Drive Replacement, Base Cover: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Hard Drive Replacement, Battery: step 2, image 1 of 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
    • Lift the hard-drive cage [2] off the hard drive assembly [3].
  4. Dell Precision 5520 Hard Drive Replacement: step 4, image 1 of 1
    • Disconnect the hard-drive cable from the system board [1].
    • Lift the hard drive off the palm rest assembly [2].
  5. Dell Precision 5520 Hard Drive Replacement: step 5, image 1 of 1
    • Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
4 other people completed this guide.
Johnathan Hammond
45,034 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 55
All Time: 7,435
