Dell Precision 5520 Memory Module Replacement
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: step 1, image 1 of 2 Dell Precision 5520 Memory Module Replacement, Base Cover: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Memory Module Replacement, Battery: step 2, image 1 of 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: step 3, image 1 of 1
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
Johnathan Hammond
45,582 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,610
