Dell Precision 7510 Memory Module Replacement
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: step 1, image 1 of 1
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: step 2, image 1 of 1
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: step 3, image 1 of 1
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: step 5, image 1 of 1
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: step 6, image 1 of 1
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: step 7, image 1 of 1
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: step 8, image 1 of 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
Finish Line
2 other people completed this guide.
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
1 Guide Comment
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 49
All Time: 11,509
