Dell Precision 7560 Battery Replacement
  1. Dell Precision 7560 Battery Replacement, Battery: step 1, image 1 of 3 Dell Precision 7560 Battery Replacement, Battery: step 1, image 2 of 3 Dell Precision 7560 Battery Replacement, Battery: step 1, image 3 of 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Battery Replacement: step 2, image 1 of 3 Dell Precision 7560 Battery Replacement: step 2, image 2 of 3 Dell Precision 7560 Battery Replacement: step 2, image 3 of 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Battery Replacement: step 3, image 1 of 3 Dell Precision 7560 Battery Replacement: step 3, image 2 of 3 Dell Precision 7560 Battery Replacement: step 3, image 3 of 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
3 other people completed this guide.
Laisha
223 Reputation
2 Guides authored
1 Guide Comment
Was able to reset a battery that stopped charging with these instructions, appreciate it!
Emiline Doerr - Reply Share
Past 24 Hours: 10
Past 7 Days: 39
Past 30 Days: 203
All Time: 3,921
