Dell Precision 7560 Fan Replacement
  1. Dell Precision 7560 Fan Replacement, Fan: step 1, image 1 of 2 Dell Precision 7560 Fan Replacement, Fan: step 1, image 2 of 2
    • The screws holding the fan in place cannot be fully removed.
    • Loosen the eight captive screws that secure the fan assembly.
    • Each screw is numbered in the order that they should be loosened.
  2. Dell Precision 7560 Fan Replacement: step 2, image 1 of 2 Dell Precision 7560 Fan Replacement: step 2, image 2 of 2
    • Locate connector cable and pull lightly to remove.
  3. Dell Precision 7560 Fan Replacement: step 3, image 1 of 2 Dell Precision 7560 Fan Replacement: step 3, image 2 of 2
    • Gently pull the first fan connector from the head until it is removed.
    • The thin wire is prone to damage. Exercise extra caution during removal.
  4. Dell Precision 7560 Fan Replacement: step 4, image 1 of 2 Dell Precision 7560 Fan Replacement: step 4, image 2 of 2
    • Gently pull the second fan connector from the head until it is removed.
  5. Dell Precision 7560 Fan Replacement: step 5, image 1 of 2 Dell Precision 7560 Fan Replacement: step 5, image 2 of 2
    • Lifting from the bottom, carefully remove the laptop's fans.
Jack Allred
351 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 145
All Time: 2,725
