Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 1 of 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 2 of 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 3 of 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 2, image 1 of 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 3, image 1 of 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 3, image 2 of 2
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
Hector
249 Reputation
2 Guides authored
One Comment
This is not for RAM this is for the SSD upgrades.
Kurtis - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 288
